Previous in Forum: Choose the Program. What Program?   Next in Forum: What's the Best XDSL Technology?
PWM Programming in C
12/15/2008 8:14 AM
im using 16f877a so using pwm how i can control the speed of the motor using clanguage coding
Re: PWM Programming in C
12/15/2008 5:36 PM
A PWM circuit can be made easily with a counter. Make a counter that counts from 1 to 100 (for instance) over and over. Your PWM value is a number between 1 and 100. Let's say you want a 25% duty cycle. While the count is between 1 and 25, you output a one (motor on). While the count is between 26 and 100, you output a zero (motor off). It works the same for any variable PWM value that you want.
You will also need to make the counter so that it counts at the correct frequency for your motor. You can do this with a second counter that controls when the first counter increments.
12/16/2008 1:18 AM
i need c coding for that portion
12/19/2008 5:13 PM
If you have been programming or know how to program the 16F877A in assembly language then may be you can convert some of the codes at the below link into the C -paradigm: http://www.piclist.com/techref/microchip/16f877adsamp.htm
Goodluck
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Register to Reply 3 comments
bhankiii (1); dinesh kumar (1); editorgbanalysts (1)
