Previous in Forum: How Do I Connect My Laptop to My Desktop Computer?   Next in Forum: Rehab Equipment Identification
Stainless Steel Tubes with Outside Threads
12/15/2008 11:24 AM
Hello all,
I am looking for a source for Stainless Steel tube that has threads on the OUTSIDE.
Not sure on the size but its in the 1/4-20 area. (Its probably the metric equivalent from just eyeballing this)
I have googled and googled and found nothing so far. So maybe if you know of a company that sells this OR if you can come up with a OTS product that uses this OR give me some "creative" search terms I would be greatly appreciative.
thanks again all you CR4'er! Your all the best!
bill12780
I'm fix'in to do somethin' stupid as hell...But I'm gonna do it anyway.
Good Answers: 266
Re: Need some leads for material
12/15/2008 12:40 PM
Is it tubing or pipe? 1/16" pipe come close to dimension you describe at .312 OD 27 thread pitch. Whats the application?
Re: Stainless Steel Tubes with Outside Threads
12/16/2008 10:27 AM
I would think that you are dealing with a pipe thread.
We could likey supply you with what you need, or any other custom made metal / stainless part and some plastic parts. what is the quantity you require, and will you supply the tubes?
As an alternative, you can likely purchase a NPT (National Pipe Taper) threading die and holder at a special cutting tool supplier. First determine what the thread you have is exactly, the tool supplier may be able to help, google for these suppliers and you will likely get more help.
If you need further assistance, don`t hesitate to ask.
Mirco
12/16/2008 11:13 PM
I am and American Engineer working in China 4 years now. depending on how much you need. it could be found very easy here. contact: caldwell_engineering at yahoo
12/18/2008 11:05 AM
Thank you all for the responses.
I am still waiting for one of the other engineers here to come back from our other location so he can tell me for sure the thread information, length, etc...
The application is we are making a sensor that screws into a mounting bracket. We use a Hamlin sensor now. But frankly the failure rate has been much higher then we like. Also, its a mechanical sensor and we would like to move to a Hall type.
I will post again after the holidays. We just found out that we are closing for two weeks for Christmas (starting tommorow..no pay of course..Merry Christmas huh?)
Anyway, I will get back with after the first of the year.
bill12780
01/07/2009 10:49 PM
Bill
Tube is normally measured in OD and pipe in ID.
You will find that tube is normally of a thinner wall than pipe.
The wall thickness of tube is not sufficient for standard NTP or BSP thread.
If you wish to maximize internal diameter and the external OD is ¼ ", you will
have to use a fine thread .
I have threaded tube in the past by using a fine gas thread.
Shocking from OZ
Anonymous Poster (1); bill12780 (1); mircoconsultant (1); nap (1); ozzb (1)
