Previous in Forum: Stainless Steel Tubes with Outside Threads   Next in Forum: Remote Temperature Monitoring
Rehab Equipment Identification
12/15/2008 4:57 PM
Hi,
I have been asked to sell an item for an estate, but I have no idea what to call it. Can anyone tell me what it would be called? It was made by Bioflex. It offers range of motion scales & adjustable resistance. Looks like you strap the forearm in and then curl & rotate the wrist/hand. Thanks for your help.
Good Answers: 101
Re: Rehab Equipment Identification
12/15/2008 8:02 PM
I don't know what it's called, but it's definitely used to strengthen your wrists and forearms.
Good Answers: 61
12/16/2008 3:32 PM
I think it's called a pronation/supination wheel. It appears to provide the same function as this item, although yours has more function/versatility. If you need further detail, try a local physical therapy clinic, or post your photos in the BioMech & BioMed forum.
12/18/2008 9:12 PM
It might be smarter not to call it anything; just let the bioflex label speak for itself. Anyone who would want it will know what it is, but not care what it's called, really. On the other hand, finding or coining a nomenclature is as likely to discourage as encourage interest. Since its only use (assuming it's not broken) is to repair a higher, bioflex-brand assembly, low price and extensive placement are the keys to getting shed of it. If you are a wholesaler, one hopes you did not pay and do not expect anything much for it.
12/22/2008 12:40 AM
It is actually to measure the angle achieved at a set tension; an evaluation tool to measure progress.
That particular outfit focuses on use of magnets as therapy.
Might be interesting to test its calibration.
I do not 'know it all', but i will admit that I would like to. CJM
Register to Reply 4 comments
Anonymous Poster (1); CJMcGill (1); DVader1000 (1); pwr2thepeople (1)
You might be interested in: Scales and Balances, Rules and Scales, Tie Down Straps
