Hello all,
I have an Investment Casting supplier that is supplying a stainless steel casting parts each do not comply with the expected corrosion resistance for that kind of alloy (duplex).
A cross section of sample after corrosion test (ASTM G48) showed that there are some holes/crevices all around the surface. First I tough it was due to corrosion but a different cross section to a sample that was not tested for corrosion showed that these holes/crevices were already there before the corrosion test.
These holes or crevices do not look like gases that come form the inside the metal since they are not round. The first suspicious in this case was the wax used. By this reason I asked to the supplier tom send me a shell after the de-waxing step. After I recieve it I could see that there is some wax remaining on the walls of the shell.
My question is: Is it possible that this wax promotes the irregular surface in the final casting?
Apart from that it is also possible to find a thin austenitic layer all around the surface (below 50 micron). It is the first time I see this phenomenon is this alloy and I'm not sure of its effect on the corrosion resistance (I'm assuming that is not good if it is not made on porpuse). The first suspicious was related to the heat treatment so I did a cross section in a sample that has not been heat treated. This analysis showed that the austenitic layer was not there before heat treatment, so apparently it is during the heat treatment that the transformation occurs. I did ask the supplier if some protective gas like N was used during the heat treatment but the answer was that NO.
Do some has a clue why this austenitic layer is formed?
Thanks in advance for your answers.
