greetings- i am a lay inventor with no background in engineering- my invention is a low tech mechanical electrical generator which utilizes a heavy weight to power a 2hp alternator that requires 700 rpm's to operate- this heavy weight is meshed to a sprocket /reduction gear complex by a sprocket chain and is hanging in mid-air beneath the alternator exerting x ft lbs of gravity induced pressure upon the sprocket gears and needs to turn the power shaft of the alternator the appropriate rpm's- my question is, how much weight is required to equal 2hp and what sort of reduction gear complex would be needed to reach a constant 700 rpm on the alternator and to allow the weight to descend at a slow , steady, constant speed - i would greatly appreciate some advice as the internet is my only tool for implementing this idea- incidentally i do have a way of raising the weight back to its ascendent position free of any energy expenditure- thanx to all, jaxon
