I've just purchased a slick little device that measures temp and relative humidity and sets off an alarm when the adjustable dew point is reached. It's powered by two AAA batteries.
The alarm is in the form of a small LED on the front and an audible beeper that emits a pulsed sound.
I wish to use this device on a large telescope to provide me with an alert when the mirrors are most likely to mist over with condensation.
That's when I turn on two small (2.5" diameter) brush-less, PM fans that blow across the face of the primary mirror. I also turn on the small heating element in the secondary mirror located at the other end of the scope. There is very little current consumed by all of these devices from the 12 VDC supply.
What I would enjoy doing is using the audible buzzer circuit to trip a relay that will automatically energize the consumers without my intervention.
Because the sound source is a square wave, something will be needed in the circuit that keeps the devises running steadily.
Any suggestions?
Thanks
L.J.
