Previous in Forum: If Gland steam temp Increases and decreases , what will be happen?   Next in Forum: Comparing ASME VIII Div.1 and Div.2?
11 comments
Soil Pressure on Buried Vessel
12/17/2008 2:26 AM
Hi,
I am designing buried pressure vessel & I want to calculate soil pressure applied on vessel. Can any body suggest me any reference books to get the information on it.
Specific query is to calculate soil pressure on buried horizontal pressure vessel diameter 2500mm x 6000mm length & burried depth 3400mm from center of vessel to ground level. what will be the external pressure because of soil load.
Thanks
Prashant
Re: Soil Pressure on Buried Vessel
12/17/2008 11:07 PM
I would recommend "Buried Pipe Design" by A. P. Moser & Steven Folkman. This, in my view, is the best textbook on buried structures available.
Good Answers: 120
12/17/2008 11:10 PM
where will the water table be on this pressure vessel? If the soil is waterlogged, the tank might feel buoyancy and want to float upwards when empty, albeit gradually. A huge number of buried tanks do this in floods.
3400 - 1250 /25 /12 = 7 feet of soil =~1200. a safety factor of 3 means you need to make it strong enough to withstand 3000 pounds per square foot. So this tank needs to be well built.
a search finds these hits, and in them you may find a reference you can use.
http://www.google.ca/search?hl=en&q=%22buried+tank%22+%2Bdesign&btnG=Google+Search&meta=
Per Ardua Ad Astra
12/18/2008 1:47 AM
Get a straight wall bucket. Fill it with the soil that will be on top of the tank. Measure the height or depth of the soil in the pail. Calculate the area of the bucket. Weigh the bucket with soil in it. Now you can calculate the weight per square mm at the measured depth. Calculate the area of the tank "shadow". This is roughly a rectangle 2500mm x 6000 mm. Multiple the "shadow" area x the weight of a square mm from the bucket. Multiply this weight by the depth 3400mm/depth in pail. This is slightly more than the tank would see due to rounded ends but fairly close with a positive error.
The weight of the soil on the tank is structural and will not affect the pressure inside the tank unless it were to crush it.
Tom Kreher
12/23/2008 1:01 AM
Hi prashant,
I have just carried out design of 10 nos of buried vessel. You can use EEUMA 190:2000 to calculate the soil pressure.
I just calculated, for you case and
Soil Weight shall be 120 tons and external soil pressure shall be 105 kg/m2. I have considered soil density as 2000 kg/m2.
Please tell me if you have any doubt.
03/31/2009 12:56 PM
Thank you very much for your replies.
10/08/2009 5:06 AM
Dear Mehta Sir,
Can u please send me the copy of EEMUA 190:2000? Either can u please send me the sample calculation report of soil pressure calculation?
Thanks in advance........
11/13/2011 12:34 AM
Dear Mehta
I am interested the same way as Markand
I thankfully request EEUMA 190:2000 copy to my email address
Thanx
Good Answers: 38
08/20/2019 11:07 AM
08/19/2019 2:59 PM
Dear Metha Sir,
I have seen your post regarding buried vessel. I need to design horizontal buried vessel of diameter 1500mm and length 5750mm.hence can you send that document of EEUMA 190:2000 to understand.
09/04/2012 6:51 AM
Be careful about external pressure and uplift force while designing the buried pressure vessel.
uplift force tends to make vessel to float.
external pressure=psi=0.433*depth(buriel) in ft*g
uplift force=lbs=vessel of volume in cubic ft*62.4 and consider that vessel is empty
Engineering problems are under-defined, there are many solutions, good, bad and indifferent. The art is to arrive at a good solution.
09/04/2012 6:53 AM
buriel depth/height is from ground level to the bottom of vessel.
Register to Reply 11 comments
ADIBA NASIR (2); alzuhd (1); Anonymous Poster (1); aurizon (1); jprashant31 (1); makrand (1); MJCronin (1); mjmehta81 (1); Ramesh123 (1); Tom Kreher (1)
