Previous in Forum: Regarding Gap voltage for VIbration probe   Next in Forum: AIR CONSUMPTION FOR PNEMATIC VALVE
Looking for LCDs
12/17/2008 3:10 AM
Dear All ,
I am looking for an LCD whose details are given below :
MAKE: OPTREX JAPAN MODEL : DMF5006NB -FW2 Processor : SED1610F x 7 SED1330F View Area : 122 x 77 mm Outer Area 180 x 112 x 17 mm ( L X B X H ) Diagonal : 5.7 inches Connector : 18 pins Can any body suggest where can we get this model or its equivalent . Also how can we check two LCD are equivalent when both have different controllers ? thanks & regards
Good Answers: 38
Re: Looking for LCDs
12/17/2008 11:12 PM
Did you try the Optrex themselves or an Importer of LCDs?
In the specification is usually written in what how the LCD communicates usually they have different options like 3 or 4 wire serial, Parallel and I2C. If that is Ok you have to check if the command set of the LCD controller are the same otherwise the driving software has to be adjusted.
LCD suppliers usually have a list of interchangeable types.
Just ask them
12/18/2008 12:49 AM
Dear All,
You can go throgh the other site like oriole and others. All LCD are equivalent only difference is pin configuration.
Good Answers: 68
12/18/2008 8:55 PM
Hello aks,
I have done a lot of searches but, it would be easier if you can tell me what this product is used it please?. Is it mono colour or full colour?
I look forward to hearing from you.
Take care and happy holiday..............
12/18/2008 11:00 PM
This is used in an instrument controller . It is monochrom with ccfl back light . The screen is with pink background with blue characters .
regards
aks
Good Answers: 38
12/18/2008 11:15 PM
a product type would be usefull, is it written somewhere? and the manufacturer is Optrex?
Good Answers: 68
12/18/2008 11:16 PM
Hello aks,
Thank you for your reply. Is it a screen which was broken in use, or are you looking to build something?
I ask because there is similar sizes models on the Optrex site. But they are not so thick as the one you list. They are around 4mm thinner. And I have no idea what resistors was it you mentioned-come with them? I will have to look but if I sent the page, you can let me know if there is anything suitable? Have you checked the Optrex site? On a search nothing comes up. But I notice the ref' codes on the sites ended in FW and that led me to look more closely.
I have also written to a company and they are replying in about 24 hours.
Take care and have a wonderful holiday......................
Good Answers: 68
12/19/2008 9:34 PM
Hello aks, this is my correspondence from Digi-Key yesterday, is under the double dashed lined. They had ref' to something like your code but, could not find anything and asked for time to search. Well I know they only search on their site and asked Optrex. But I checked on the Optrex site and no luck. If you can tell me more details I might be able to do a fuller search. How old in the product you want this screen for, because it may be cheaper to get a new product than get a new screen. Things are changing all the time. Every screen I saw at roughly the size (w x H) were 3 to 6 mm shallower than yours. In general terms, what is the type of device the screen came out of? If I know that I could perhaps find some maintenance company who may have a spare? Where are you based, which country and rough area please?.....I do not want to be looking in the US, if you are in Australia! Get back to me please. What searches have you done to try and find this? What product is this screen from? The exact size? How does it fit in the product? What is the largest and smallest screen that will fit? Do you need the IC's you mentioned in the first post? Can you get these IC's from another source? Does any new screen come with these IC's needed to make it work? ================================================== The correspondence from Digi-Key is below. It includes links to the Digi-Key site and tel #. Hello Q, Thank you for your patience. According to our contact at Optrex, that part is extremely old. There is no replacement or anything even close.
Let me know if I can be of further assistance.
Jon Mauriala
Jon.Mauriala@digikey.com
Technical Support Specialist II (Logic/Op Amps)
Digi-Key Corp.
www.digikey.com
1-800-344-4539 Ext. 2346
Digi-Key Technical Support and Design Support Services strive to provide the most accurate and up to date information to our customers. It is the sole responsibility of the customer to confirm and validate the assistance, recommendations, and specifications as well as determine the appropriateness and compatibility of part selection applicable to their project or design. (For further information refer to "Terms & Conditions" http://dkc1.digikey.com/us/mkt/Terms.html)
RoHS compliant and lead free information supplied by Digi-Key is based solely on information provided to Digi-Key by the manufacturer. Digi-Key is not
[19:03:04] Jon ext 2346: Welcome to Digi-Key Live-Help. How may I assist you?
[19:03:21] Q: Hello and merry xmas........
[19:03:37] Q: Can you help me find this LCD please?
[19:03:41] Jon ext 2346: Hello
[19:03:47] Q: MAKE: OPTREX JAPAN MODEL : DMF5006NB -FW2 Processor : SED1610F x 7 SED1330F View Area : 122 x 77 mm Outer Area 180 x 112 x 17 mm ( L X B X H ) Diagonal : 5.7 inches Connector : 18 pins Can any body suggest where can we get this model or its equivalent
[19:04:35] Jon ext 2346: Are you able to hold for a moment while I do some research?
[19:04:44] Q: The size is important
[19:04:55] Q: yes I will wait
[19:07:11] Jon ext 2346: I cannot verify that part number, I will have to contact my product manager in order to find out if we can get this part or not
responsible for the accuracy of this information.
Due to the prototyping nature of engineering quantities, when products are ordered in less than standard manufacturer's packaging, moisture sensitive product may not be packaged in MSL compliant packaging. If you require MSL packaging for moisture sensitive product, please order in standard manufacturer's packaging.
Register to Reply 7 comments
aks (1); Anonymous Poster (1); babybear (3); Epke (2)
