Previous in Forum: Chemicals, Carbon Filters and Resin Activation   Next in Forum: Degreasing a Valve for Nitrogen Service
Temperature and PR Limits
12/17/2008 9:28 PM
Spec calls for : Cl 150 RF , S 31803/32205 Duplex SS , 0.063" CA , DSS Trim ( NACE Complt ) Design Code : ASME B31.3 Pipe MOC : DSS A 790 - S31803/32205 Seamless / EFW Large Fit MOC : DSS A 815 – S31803/32205 Small Fit MOC : DSS A 182 – F 51/60 T & Pr lts : -20 to 600 F @ 290 to 140 psig ( max ) as per B16.5 Grp 2.8 Service : Blowdown , Acid gas , Sour water However if I look in ANSI B 16.5 for DSS A 182 – F 51 , T & Pr lts are 100 to 600 F @ 290 to 140 psig . How can I see the limits for -20 to 100 F ? Thanks in advance
Be simple and specific for a great success in Life
Re: Temp & Pr limits
12/18/2008 8:55 AM
What kind of product is this?
Re: Temperature and PR Limits
12/18/2008 10:33 AM
Check B31.3 allowable strengths Table A-1 (page 160 - 2006) and run them through paragraph 304.1.2
(I gave the cop-out answer because I am at "busy" at work and don't want to make a stupid mistake like I did to your last "min wall thickness" question and I can't really decipher your question/determine your problem [isn't the answer to your question in your question already?] )
12/18/2008 1:32 PM
............... see, there I go again - not fully reading the question/mixing up my standards/codes. You are asking B16.5 flanges and not B31.3 piping.
You are right - it is interesting that they left out/missed (it looks like a typo) the -20F rating in the 2.8 table for imperial units. However, if you look at the metric units for 2.8 materials they have noted -29C to 38C. So I would just convert the metric units - which works out to be 290psig from -20F to 100F anyways.
12/19/2008 10:44 AM
Below 100 deg ,upto -29 deg the pressure rating is the same as listed for 100 Deg F
For example for 150# ANSI steel flange the listing is as follows
-20 to 100 Deg F 285 Psig.
If you don't know where you are going,you are bound to get there
Register to Reply 4 comments
Anonymous Poster (1); Guest. (2); srini (1)
