Hey good folks.
At what point does a vessel become a pressure vessel subject to ASME code requirements? We've got a box made from a hogged out solid piece of 6061-T6 Aluminum that is 24" x 29" x 5" tall. The walls are all 0.500" thick and the whole thing is anodized. The lid is a flat piece of aluminum same specs and thickness and there is a 21" diameter hole in the middle of it. To the bottom surface of the lid is glued a flat piece of silicone rubber 1/4" thick and there is a fill port 1/4" tap on the top. This lid is clamped down with several 2000# welding clamps and additional peripheral clamps. There is a 24" diameter, 1/8" thick, thermoformed ABS round tub on a structural plate that has 2.5" high wall that is put inside it. I calculated the volume to be around 1.2 cubic feet. This whole thing pressurizes to 1 PSIG now.
The idea is to increase the pressure to help aid in finding any leaks of the structural to tub interface and working sealed penetrations on top of the tub. The tub is filled with 2" of water to cover the sealed working features and bubbles are sought visually. Can the pressure be raised, and to what point before the code applies, or does it apply now? This is a serious safety issue, so I'm looking for someone who has or know the code please. Thanks in advance!
Don
There are people who make things happen, there are people who watch things happen, and there are people who wonder what happened. To be successful, you need to be a person who makes things happen.. Jim Lovell, NASA Apollo 13 Hero
