Previous in Forum: Three-Way Hygienic Continuous-Activated Valve   Next in Forum: SIL levels
Equalization Line
12/20/2008 12:38 AM
Ref to attached PFD , Wats the purpose of equalisation line n y its callled so
Re: Equalization Line
12/21/2008 4:56 AM
I think you need to be more specific as where the equalizing line is coming from.
It could be used for start-up ops.
12/21/2008 12:45 PM
Plz note that its not orginating from any source, that line itself is defined as equalization line
Regards
Jose
12/22/2008 1:12 AM
It should be to equalize any of the required process parameters like pressure. level in the Horizontal tanks SG-V-206 & SG-V-207. You can attempt to co-relate with the equalisation valve in a 3-way or a 5-way manifold.
Regards
KA.Shreekrishna
06/21/2023 7:21 AM
There should be a document related to the <...PFD...> called a Process Description, or something similar. It should be in there.
Otherwise, how would anyone know what to do to either operate the existing process or modify it so that it can take on a (partially) new role (rhetorical question - NNTR)?
Register to Reply 4 comments
Anonymous Poster (2); Mercor (1); PWSlack (1)
You might be interested in: Line-shaft Spools, Power Line Network Components
