Previous in Forum: oil and gas industry   Next in Forum: pumps
what is difference between working point elevation and centerline elevation?
12/20/2008 8:18 AM
hello Gentleman
my first question is
1)what is difference between working point elevation and centerline elevation?
2)what is difference between PSV(pressure safety valve) and TSV(thermal safety valve)? as i know PSV release access pressure within system but What is function of TSV, currently i am busy in LNG project.
Good Answers: 61
Re: what is difference between working point elevation and centerline elevation?
12/20/2008 11:18 AM
1, The center line is what it is and cannot be changed. A "Working Point is what ever you want it to be for your project. It could be the bottom of the pipe. It could be the invert (inside bottom) of the pipe. It could be the top of the pipe. It can be any thing you want or fits the situation as long as you define what you want it to be.
2, A "PSV" releases pressure. A "PRV" releases pressure. A "TSV" releases pressure. The only difference is in what it is called.
Do it once and do it right
12/20/2008 12:06 PM
Based on the technical level of your questions, I hope you are not specifying components for this LNG project.
Are you a student?
12/21/2008 3:32 AM
no i am not student , i am a piping engineer
on LNG carraing pipe these two PSV and TSV are there.
outlet of Both valves are Natural gas.
12/21/2008 5:27 AM
A PSV relieves the pressure due to an upset in operation to protect people and equipment.
A TSV protects a blocked-in equipment,generaly a pipe, which is left standing full of product, that can expand under rising thermal conditions as outside temp, heat tracing failure etc.
calculations for either of them are very different.
In general a PSV is much bigger in size than a TSV
Hope this gives a general idea.
All above mentioned calculations are to be certified
12/22/2008 5:40 PM
God help us all.
Travis
Anonymous Poster (1); lyn (1); Mercor (1); PennPiper (1); pranavchaudhari (1)
