Previous in Forum: what is difference between working point elevation and centerline elevation?   Next in Forum: welding
pumps
12/20/2008 1:16 PM
how to select pumps for difference purpose
Re: pumps
12/20/2008 11:53 PM
Dear Mohamed
Mainly,you have to determine the value of the following (the conditions of your case):
1-The flow rate.
2-The fluid you transfer.(viscosity,temp,allowable solids,toxic,expensive ...etc).
3-Pulsating (or non) discharge.
4-NPSH
5-Head to be pumped to.
6-The allable noise.
7-The possibility of running dry.
8-Expensive or cheap one.
please ,visit these sites:
www.pumpschool.com
www.vikingpump.com/pumpselector/
www.lightmypump.com/pump_glossary.htm
thanks
Aly
Re: pumps
12/21/2008 10:24 AM
You must also take into consideration suction lift or head.
Re: pumps
01/27/2013 11:37 AM
Dear Mr.AlyBadway,
I want to supplement the following points in addition to your Points:
1. Horizontal Split Casing/Vertical Type to be decided.
2. Priming Method/Flooded Suction to be decided.
3. Mechanical Seal is required or not.
4. Cavitation Possibility to be known and measure to be taken to avoid it.
5. Material Selection of Pump Construction to be decided.
Thanks,
DHAYANANDHAN.S
Re: pumps
12/22/2008 9:11 AM
I have sold many pumps over the years for many different applications. I remember talking to a young engineer a few years back. I handed him my card. He told me that he didn't know much about pumps and I told him "Everything you need to know is right there on that card." My advice to you is to get with a reputable pump sales engineer and he will direct you to the type, size, etc. of pump you need.
All that is necessary for the triumph of evil is for good men to do nothing. - Edmund Burke
Register to Reply 4 comments
Aly Badawy (1); dhayanandhan (1); Tazman20 (1); The Commoner (1)
