Previous in Forum: Early Christmas Present   Next in Forum: Remote Learning in India
Shear stress
12/21/2008 1:34 PM
Why is it that when we got shear strain the length of the sides of the beam don't get longer, but it changes form?
Re: Shear stress
12/21/2008 2:08 PM
The clue is in the words 'longer' and 'shear'
Surely 'shear' implies 'across' rather than 'along' the axis of a beam or whatever.
Maybe you should post a picture/diagram of what is troubling you...it may ellicit more intelligent replies than mine?
Re: Shear stress
12/21/2008 4:16 PM
Are you familiar with Poisson's Ratio? If so, it seems to apply. If not, you must learn that.
A harmless necessary cat - The Merchant of Venice
Re: Shear stress
12/21/2008 7:14 PM
http://img201.imageshack.us/my.php?image=bilde004gg3.jpg¨
As you can see from the picture, the shear stress does not make the sides of the square longer(the sides only rotate), why?
Guest: I am familier with Poisson's ratio, but this subject has nothing to do with that. Normal strains are affected by Poisson's ratio, shear strains are not.
Re: Shear stress
12/21/2008 11:49 PM
Looking at it from a pure mathematical point of view:
For an isotropic material subjected to a general state of stress in which all stress components are present, the strain and stress are related by:
εx=(1/E)[σx-ν(σy+σz)]
εy=(1/E)[σy-ν(σx+σz)]
εz=(1/E)[σz-ν(σx+σy)]
τxy=Gγxy
τyz=Gγyz
τxz=Gγxz
Then in the special case of plane stress where the normal stresses in the x and y-direction are zero as well, the above equations reduce to:
εx=εy=εz=0
γxy=τxy/G
Therefore - you don't have a change in length of the sides.
(in defence of Guest above: Poisson's ratio is indirectly relevant through the relation G=E/[2(1+ν)]
Re: Shear stress
12/22/2008 8:14 AM
Guest(1),
I apologize; I misunderstood your question.
In the case of pure shear stress, as seen in theory books, Poisson's Ratio is not relevant (except as noted by Guest(3) above). I thought you were asking an applied question, in which case it is relevant.
Guest(2)
We have seen better days. - Timon of Athens
Anonymous Poster (3); Guest. (1); user-deleted-1105 (1)
