Previous in Forum: P.R.V.   Next in Forum: How to Calibrate Pressure Gauges In-House
8 comments
Gantry Robots and Component Picking
12/22/2008 11:23 PM
how to stack a round component which is to be picked by gantry robot in same orientation.
Good Answers: 38
Re: about gantry
12/23/2008 8:10 AM
Carefully. How about in a pyramid fashion if room allows. I guess it would matter how large the items are. This would tend to be the most stable. Just like in the grocery store for display. Just don't try to take the ones from the bottom first.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Re: Gantry Robots and Component Picking
12/24/2008 7:58 AM
Hi Smith,
Use a vision system on the gantry, and locate a unique pattern on your part. If there is no uniqueness about the part create a paint dot or similar in one of the previous operations, then use it to locate. You could use a servo / encoder for the rotation.
Mirco
12/24/2008 8:58 AM
Is "round" as in sphere, cylinder, or disk?
Good Answers: 25
12/25/2008 6:11 AM
Your question is not complete with detailed information. Please give information about the item to be lifted etc.
Good Answers: 119
12/29/2008 4:17 PM
You really need to supply more specific information but I once spent a large chunk of time designing and machining acrylic plastic component nests that were mounted on vibrator tables.
The idea was to randomly dump the components from bins onto the nest, then "shake" the nest and components until they fell into carefully designed recesses in the nests. Then the nests were moved (by robot) to an assembly line with pick and place robots (2 and 3 axis) to assemble sub-assemblies and the final product.
Pre-orienting components using this method saved a lot of time and money in high-speed, high-volume assembly without the complexity and cost of programming >3 axis robots.
Hooker
12/29/2008 5:36 PM
I can see how that would work, but you have to admit, shaking the components into their proper nests sounds an awful lot like the room full of monkeys with typewriters eventually writing the complete works of Shakespeare.
Good Answers: 119
12/30/2008 8:57 AM
I hear you but when it comes to assembling tens or hundreds of thousands of a consumer product it was quite cost and time effective.
There's no way a vision system and robotic re-positioner could keep up on that scale.
And there's no mess to clean up like when using monkeys.
Hooker
12/30/2008 9:42 AM
That's a valid point - all those lunch scraps alone would be a major headache...
Register to Reply 8 comments
charsley99 (1); EnviroMan (3); Hooker (2); mircoconsultant (1); suresh sharma (1)
