Previous in Forum: Gantry Robots and Component Picking   Next in Forum: Marry Christmass and a Happy New Year
21 comments
How to Calibrate Pressure Gauges In-House
12/23/2008 12:24 AM
Hi,
We have many pressure gaues in our organisation. The cost of calibration of the pressure gauges by external agency is to much high. So we need the instrument that calibrate our pressure gauges inhouse, which is reliable, and accurate. So any one have any information about method of inhouse calibration of pressure gauge.
Yogesh.
09767896010
Re: How to calibrate pressure gauge inhouse
12/23/2008 7:09 AM
Sounds like you need a deadweight tester. Depending on the amount of gauges you are speaking of you may need a dedicated person as well.
If you fail to follow through, you will fail.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: How to Calibrate Pressure Gauges In-House
12/23/2008 9:20 AM
Yes, a dead weight tester would be the perfect solution, however they are quite expensive. Another option would be to buy new gauges in the ranges that you use, and send these out for calibration. Label them "Standards", and don't let them leave your lab. Make up a test rig and periodically compare your field instruments to these.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
12/23/2008 11:33 AM
Good idea, Bricktop, for practical application. It's very witty from position of common sense.
There are only two issues though. For one - is one completely legal, for two - from a classic metrological approach those "Standard" gauges should be matched at least 3 times higher accuracy class than field's ones. So it'd be turned out as the same pricey solution along with an ambiguous legacy.
Good Answers: 73
12/23/2008 11:40 AM
Oh, I agree. Any method would have to depend on the level of accuracy required, and if traceability is required.
It is very difficult to give a "right" answer when the OP gives so little information to go on.
12/23/2008 11:18 PM
Yes, he will need Dead Weight Pressure Guage tester. The price will depend up on the accuracy we are looking for.
Standard pressure guage to compare will also be costly, as as you say it needs to be few orders high in accuracy than what acuracy we are looking for. Besides, this pressure guage needs to be calibrated and validated periodically from standard laboratory with international traceability.
Even if we keep in house DWPT, the instrument needs traceabilty and certification from accrediting authorities... its plunger diameter and the weights being used.
But, if we compare the two methods... DWPT and the calibrated high accuracy guage as standard, DWPT is better option, as it is less prone problems like going defective and getting calibration shift, as pressure guage may face. Besides, if you have number of guages to be calibrated periodically, this is the best choice.
The operation of DWPT is very simple. Need of dedicated person depends upon the number of guages to be calibrated (this will be needed even if you use standard high accuracy guage). Anybody wth little training can operate the DWPT.
12/23/2008 4:14 PM
Price will depend on pressure range and accuracy required but you might find something here: http://www.coleparmer.co.uk/catalog/product_view.asp?sku=6803500
Charlie don't surf.
12/23/2008 11:06 PM
Have a look at this thread, I was looking at a similar problem.
http://cr4.globalspec.com/thread/30836
The nice thing about Standards is there are so many to choose from.
12/23/2008 11:20 PM
You will find several dead weight testers for sale in Ebay, they have various ranges also most are not warranted. But generally speaking a dead weight tester produces the correct pressure with the weights supplied unless there is something seriously wrong with the equipment.
If you have to produce a warranted accuracy the equipment will have to be certified also you will need a clean room and an certified operator all approved by the relevant authority. If you are happy with in house tests to your own standard and not requiring public reliability there is no reason why a dead weight tester should not do the job.
If you are testing other than hydraulic gauges you will need an isolation testing chamber to avoid contaminating the gauges.
12/24/2008 12:11 AM
Hello, try this new product from GE Druck. Relatively inexpensive compared to a deadweight tester and the pressure modules are interchangable so you can alternate different ranges with the same basic set-up. The electronics also detach from the pressure simulation unit and can be used as a temp and electronic calibrator.
http://www.gesensing.com/products/amc.htm?bc=null
Full disclosure, I am a sales rep for this product in the US.
Good Answers: 16
12/24/2008 9:22 AM
Ok, now lets get down to the "skinny", that machine costs what?
Good Answers: 73
12/24/2008 10:02 AM
12/24/2008 6:09 AM
Depending on the pressure range, saturated gasses, I'm thinking specifically of refrigerants have a known pressure at a temperature. the gas could be heated or cooled and it's pressure looked up on a TP chart. You would want to do this over a range of pressures.
Good Answers: 103
12/24/2008 7:13 AM
It all depends on the requirement of the Gauges, If the gauges used for calibration (The masters) can not be traced to any of the standard laboratories, the calibration will not have any validity.
However for working gauges (not inspection gauges) this may not be a problem - unless the QMS/ OHSAS auditor objects.
I was looking at some sites, earlier, and had some interesting readings on solid state pressure gauges- of course piezo is ruled out (being dynamic), strain gauges may be OK and these normally have much more stability (and compensatable) for temperature etc changes.
check this site
www.sensorsmag.com/articles/1198/fun1198/main.shtml
it has some interesting readings
12/24/2008 8:27 AM
Guages that are used for calibration at one time had a thin strip of mirror material behind the needle so that you could align the needle front to back for a precise reading. Do they still do that?
12/24/2008 9:09 AM
Welcome aboard! I'm guessing you are not in the United States, but just in case, for DWPT and also pressure testers with reference gauges (which can be used for calibration), try McMaster-Carr at < www.mcmaster.com >
Location: USA Soviet Socialist Dictatorship of Cook County& Illinois
Good Answers: 15
12/24/2008 9:10 AM
The advice of the responses to use a dead weight tester is correct, however these "standards" have to be calibrated and THAT is very expensive. Your quality plan dictates how often gauges and standards have to be calibrated. The key is to determine what is reasonable and what guarantees that the gauges in use are accurate. If all your gauges are used for testing, the calibration should be yearly unless dropped or mishandled. If they are process gauges, they may need calibrated more often. In my plant our gauges are for testing vessels. We calibrate our gauges every year using a dead weight tester. We calibrate the dead weight tester every 10 years. It works for us. A combination of "standard" gauges, as suggested is good. Buy the dead weight tester, calibrated and write your plan so as to insure accuracy. It is reasonable to calibrate a dead weight tester every 10 years.
I often think the QA people are inadvertantly in the business of making sure the "Labs" have good cash flow.
12/24/2008 10:41 AM
I'm very happy to see all of you trying to help. In my company we use a "standard" gauge, (calibrated every year on a national laboratory) to calibrate pressure gauges installed on facilities and production equipment. With a precision of 0,01% full scale, we have an accuracy 10 times higher than the normal pressure gauges that we calibrate internally. We use a Keller LEX1 with a manual pressure pump (K/P Handpump). This system is very good to operate on field and it costs around 1300€ (cable and software included for data logging) I hope that this information can help. Best regards, Filipe Rocha Activeng, Lda
12/24/2008 10:56 AM
If you are looking for cheap, why not clean a porta-power pumping unit replace the oil with a mixture of glycerine and water tee that off to a calibrated test guage and the guage being set?
12/27/2008 7:04 AM
Thanks to all for replying my problem. I will Definately follow yours suggestions.
Yogesh.
01/08/2009 8:22 PM
Hi
in the past i faced same problem in our company so I asked for new eq. to make calibration for pressure gauges, Finally we bought a device from CRYSTAL ENGINEERING (search by google to find it)
the calibration method is too easy and try to read the manuls online.
09/28/2009 3:41 PM
Dear Yogesh,
You can buy the equipment can calibrate your gauges but will cost you for that equipment to purchase and you need to certify that equipment every year. How much is a cost to certify? where do you get certify your gauges. let me know i can get it done chipper or if you like to purchase the equipment i will sale to you. send me an emai at rakesh@gemcous.com, cell # 201-218-6930
Register to Reply 21 comments
Anonymous Poster (4); Bricktop (3); caramba (1); ckartson (1); EnviroMan (1); garth (1); gsuhas (1); Morgan 23 (1); Naif (1); otha (3); sb (1); stevem (1); Tim in Mexico (1); Tonymech (1)
You might be interested in: Pressure Gauges, Digital Pressure Gauges, Strain Gauges
