Previous in Forum: Marry Christmass and a Happy New Year   Next in Forum: What is a Double-Crank Slider Chain Mechanism?
8 comments
Codes for Boilers and Steam Generators
12/23/2008 1:05 PM
is there any difference between boiler and steam generator when applying codes
if there is ,any one can help
specially in inspection
Good Answers: 19
Re: steam generator
12/23/2008 1:48 PM
Take it like this. A Boiler has a steam storage and a steam generator does not.A boiler will take some time to give you steam whereas a steam generator will immediately give you steam. Rest please read a book on Boiler & their types which will help you understand better.
Re: steam generator
12/23/2008 9:33 PM
thank you
but is there any difference in applying code for both
specially in inspection codes
Re: steam generator
12/25/2008 2:31 AM
ASME Code BPVC Sections:
I Rules for Construction of Power Boilers
IV Rules for Construction of Heating Boilers
VI Recommended Rules for the Care and Operation of Heating Boilers
VII Recommended Guidelines for the Care of Power Boilers
Re: Codes for Boilers and Steam Generators
12/25/2008 4:13 AM
thank you
but which part we have to apply for steam generator
specially in inspec tion
12/26/2008 6:51 AM
• ASME Code Section I, Rules for Construction of Power Boilers, and
• ASME B31.1, Power Piping.
12/26/2008 9:15 PM
Depending on the details of your steam generator - pressure, temperature, size/capacity, stationary/portable, nuclear, locomotive, miniature, ............... - to determine the applicable ASME code;
You may also find inspection practices in API 573.
12/30/2008 11:30 AM
Yo entiendo una caldera puede ser hasta para suministrar agua caliente, en cambio un generador de vapor, es como el nombre lo indica genera vapor, y las presiones son distintas asi como las inspecciones y rutinas de mantenimiento,
12/30/2008 12:27 PM
gracias
Register to Reply 8 comments
Abdel Halim Galala (2); Anonymous Poster (2); ducon (1); mostafaalkholy (3)
