Previous in Forum: Gas Insulated Switchgear (GIS) Reference Materials   Next in Forum: Preventive Maintenance for Batteries
India - Member - New Member
How to Select a Substation Transformer
12/24/2008 2:23 AM
Dear all
Auto transformer is used 230KV and 400 KV substations only.Any technical points behind it.
what are the deciding factors to be considered for choosing a auto transformer.
gova
Chennai-India
Re: Auto transformer
12/24/2008 4:12 AM
Dear SIr,
In the 220 KV & 400 kV the Transformer Size may be large to accomadate heavier High Voltage Windings. That's why Auto transformer is used. But it is not necessary that all the 220 kV & 400 kV Shall have Auto transformers. If the Client requires it may be 2 winding or 3 winding transformer. The undersigned have the experience of using 400/220/33 kV 3 winding (primary, Secondary, tertairy winding) Transformer.
Regards,
N.Suresh
12/26/2008 7:59 AM
Dear suresh
Thank u very much.
And I invite other members also to share their views
Regards
gova
04/20/2010 3:06 PM
hey,
i need a a project for auto transformer protection schema
if u have that, can u send me?
thanks for now
Either exist as you are or be as you look. Rumi
12/24/2008 7:39 AM
How much the power is?
12/26/2008 7:57 AM
dear sir
Minimum power is 100MVA
Regards
gova
Re: How to Select a Substation Transformer
12/29/2008 9:46 PM
Dear Sir,
The Auto transformer is used in HVSubstation due to followinfg reasons.
1)If we use normal transformer the size of transformer will be very high which leads to heavy weight,more copper and high cost.
2)The tertiary winding used in Auto transformer balances single phase unbalanced loads connected to secondary and it does not pass on these unbalanced currents to Primary side.Hence Harmonics and voltage unbalance are eliminated.
3)Further Tertiary winding in the Auto Transformer balances ampturns sothat Auto transformer achieves magnetic separation like two winding transformers.
Regards
V.Ambarani
Best Regards
04/20/2010 6:55 PM
Register to Reply 7 comments
Anonymous Poster (1); cnpower (1); engilis (1); gova1467 (2); V.Ambarani. (1); wareagle (1)
