Previous in Forum: Boundry wall   Next in Forum: Calculation Construction Measurement
14 comments
Casting Concrete On-Site
12/24/2008 11:12 AM
what is suitable way to cast 13000 m3 of concrete at site .
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Casting Concrete On-Site
12/24/2008 1:12 PM
Formwork.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
India - Member - New Member
12/25/2008 2:06 AM
what is the duration in which you are going to cast 13000m3?
and i required in which member (raft,wall,column,roof) you are going to pour?
give me the details so thst i can give you the best solution
12/25/2008 10:17 AM
Thanks for ur concern and the duration is two days plus the member is raft without construction joint. if required construction joint what is the way for that and explain the best places for it.
12/26/2008 5:36 AM
The volume concrete is for water tank is it?
Good Answers: 25
12/26/2008 8:54 AM
Wowser!! That is about 1500 cement trucks in 2 days? Better call Cecil B. DeMille.
Goodness has nothing to do with it.
12/26/2008 9:50 AM
No offense, but I think you are in the wrong line of work.
By any standard, that's a lot of concrete and it would be foolish to enter into such a project without any knowledge of the processes involved or the scope of the job.
Unless you are mixing the concrete by hand, I assume that someone will be supplying you with this mountain of cement and sand and maybe they would have an idea about how to cast 13000 m3 of concrete.
While I'm ranting, the amount of information provided by you, and too many others, in posting these questions makes it impossible to give even a remotely intelligent response to the question.
What are you thinking?
12/26/2008 1:32 PM
ha ha ha ha ha ha u r the intilgenat one i think ?
12/30/2008 2:00 AM
why you think these impossible to occur!!! 13000 m3 actually is volume concrete can supply for casting mega water tank or mega sewerage treatment plant!!! Difference company will use difference method to cast that structure!! the method will depend by the company who will construct it !!!
12/26/2008 11:28 AM
Did you consider using precast as an alternative!
Courage is contiguous: When one brave man takes a stand, the backs of others stiffen!
12/26/2008 11:34 AM
to lynlynch !!!!!!............................. why you think these impossible to occur!!! 13000 m3 actually is volume concrete can supply for casting mega water tank or mega sewerage treatment plant!!! Difference company will use difference method to cast that structure!! the method will depend by the company who will construct it !!!
12/31/2008 2:52 PM
Slip form .large elevators do it all the time. several turcks on site around the clock. have fun.james m kieffer
01/04/2009 11:11 PM
think about researching how the Hoover Dam was built---that is one way. site processing all materials, mixing on site, pouring on-site.--precast, as mentioned before, is another alternative, but requires large equiptment to deliver and stand up , and connect the panels -then you have pour-in-place- and stand up structures (think and research "Tilt-ups"--think Home Depot , Lowes, Large Warehouse structures)---do your homework, consult local concrete and structural engineers, and you will not need to even consult this forum to find your method---C-MAC
01/11/2009 8:47 AM
This is a herculean task . First and foremost , what sort of structure it is? Is it a Raft foundation ?
This is what I would do :-
i) Get a layout plan and identify access for concrete trucks and prepare traffic management plan
ii) Identify the type and capacity of plant to be used - ie elephant pump. I think the elephant pump can discharge about 40 to 50 cu.m/hour .
iii) identify the number of concrete supplying plant and its cycle time. You may need 10 plants with capacity of 40 cu.m/hour , i.e 400 cu.m /hour . It will take about 32.5 hours continuous supply to complete
iv) Number of trucks /plant ; depends on cycle time
v) Plan your manpower - For every discharge points - you may need 10 to 12 workers/shift of 8 hours
vi) Provide adequate vibrators - 4 units /gang
vii) Discuss the plan with your supervising team
01/11/2009 5:53 PM
This last point is valid and is how this project should be approached. You do not want to get started and then find you do not have the means to finish.
Register to Reply 14 comments
Anonymous Poster (4); beriberi (1); Bricktop (1); C-Mac (1); dody (2); karfung (2); kgb78_2002 (1); lyn (1); tarzete (1)
