Previous in Forum: frp pipe   Next in Forum: relief valve size
10 comments
How to calculate weld reinforcement for branch fitting?
12/27/2008 2:54 AM
My problem is about branch connection. In my project, half coupling was provided to use as a branch fitting, large gap between pipe and fitting founded. I decide to make a full penetration, around 8 layers were applied. Finally, I found some distortion occurred after welding.
Sample case :The defect is distortion around weld toe, approximately 2mm from OD pipe.
Half coupling : SS304,1.5",3000 lb, cut straight at bottom and then bevel 45degree
Main pipe : SS304,4",Sch 10S
From the above problem, some supervisor recommended me to weld only 4 layers ,he told some projects did like he said. I don't know he said right or wrong but I'm an engineer I try to make this matter clear ,verified by calculation. For this situation, how should I do?
Chalermphol C., Thailand , Petrochemical plant
Re: How to calculate weld reinforcement for branch fitting?
12/27/2008 3:17 AM
Before a messy discussion/"argument" ensues regarding the weld strength of this connection.
Is it possible to spec another fitting such as the "pipets" from WFI that are made for this exact case to avoid weld distortion?
(look under "products" and they should be on the first page")
http://www.wfi-intl.com/
12/27/2008 10:56 PM
As an engineer you should straight forward reject the half coupling.Only allow weld-o-let for a branch connection.Use ASME Code B31.3 for further support your decision.
12/28/2008 2:47 AM
1. I prefer to use Reducing Tee 4"x1.5" NPS, or at least Weldolet 4"/1.5" NPS (if it is available). Otherwise:
2. You can make an appropriate curvature for that half coupling 1.5" NPS to match with the curvature of the main run 4" NPS, to be beveled and butt-welded and add a fillet weld with a leg not more than the thinner of welded thicknesses. Or
3. If it is possible, you can use the half coupling to be welded as "set in" not "set on", and in this case the hole in pipe can be beveled to be butt-welded followed by a fillet weld around the half coupling with the same leg as in "2".
Note: For all prescribed cases and as you use standard fittings with appropriate dimensions/schedules/ratings/classes, no need to proceed any calculations.
12/28/2008 4:50 PM
First of all you can buy real nice weld on branch fittings you can weld on in one pass or cut the pipe or coupling with two cuts 45degree or 60 degree what ever fits better to get the branch closer to the pipe to maybe two passses we used this in the race car years ago
Mike
12/29/2008 3:38 AM
Thank you for every answer.
In this project ,I can't reject these fittings because of time schedule.
One point, that make me doubt, is calculation method for weld reinforcement. I can't find any document that refered calculated method. Normally, if we weld full penetration , it will be safe. Interesting thing is if we cannot do it, what solution shall be applied?
Now , I have two choises
1 Full penetration: I have to discuss with the authorized person in project for approved such a defect.
2 Not full penetration: Find some document that sound for proving size and shape of reinforcement.I would like to find some clue ,if anyone have it please tell me more.
Thanks you sir,
Chalermphol C. Thailand
12/29/2008 9:39 PM
Please look into ASME B31.3, paragraph 328.5.4 - particularly Fig 328.5.4D.
Hobbies - DIY Welding - pipewelder
12/30/2008 2:01 PM
I think you are over killing on the amount of weld and this will cause distortion. Half couplings work great on lower pressure(below 150 psi) branch connections especially on stainless steel pipe because it draws or distorts more. When people tell you to not use a half coupling for a branch connection it is incorrect that is what they are made for. Please keep in mind that half couplings are not made for steam and other higher pressure services but more for fire protection, water, air etc. I have been welding both half couplings and weldolets on for near 30 years and I one thing I know for sure is that welders nearly always put way to much weld on them. I will garantee that if you fully weld on a threadolet on stainless steel you probably won't draw the threads on the threadolet but you will draw the header so badly that that it could be ruined. I agree with Ashim (as always and he gets my GA) on the points he made about the installation procedures. I always install half couplings in a "saddle in" technique as opposed to a "saddle on" technique to reduce distortion.
pipewelder
07/23/2013 2:12 AM
pipewelder,
just replied one in section weldolet welding. most of the time the design engineering mis- interpretes the definition of groove. also they miss to visit the section of un- listed fittings of asme b31.3 where on the welding thickness, the code recommends to interpolate.
ciao
ashbandy
AshBandy
01/08/2009 1:47 AM
See ASME B31.3
APPENDIX H
SAMPLE CALCULATIONS FOR BRANCHREINFORCEMENT
I think it is helpful
Regards
04/04/2014 3:38 AM
Refer ASME B 31.3.Check the header pipe cut-out(May be this is the reason for overwelding).you can go for 4" X 1.5" TEE OR WELDOLET for SS.
Abdel Halim Galala (1); ahmed301 (1); Anonymous Poster (3); ashbandy (1); Guest. (2); Naif (1); pipewelder (1)
