Hi,
I got this problem at work, where one of my exhaust Fan keep trip after run for awhile. the Exhaust fan is run on timer with two fan running that one run, the other standby.Both are run with VSD. The First exhaust fan VSD had be replace a couple monts ago where the VSD found to be faulty. The new VSD is getting back the same brand but different model as the existing model had be replace.
This trip is quite happen a few mth ago, after the replace the VSD it gone. But come back again. Both of my VSD and fan contractor found that their equipments are runing fine. We even manual run the exhaust fan, it work and the cable for the exhaust fan is check also to see any current leakage. but found none.
Only the first exhaust fan trip when running, while the second exhaust fan found to had not that problem.
Can anyone advise me on that ?what wrong with that.
