Hi Every One, & Happy New Year.
I have a DC motor 220 V. I want to control its speed throw controlling its FIELD & Armature Voltage.
If we connected the field & armature both directly to 220 V DC, the maximum speed will be around 490/RPM.
I need to make a circuit to control the motor :
- first 5 seconds with normal speed
- then I need to increase the speed to be around RPM * 2
as every one know, if we connect the armature directly to 220 V DC but decreased the field voltage (100 V DC as example ) the RPM will Increases.
I tried this situation manually several times & it works very will. Also for both direction (Right & left). The reading was :
Arm. Voltage, Field Voltage, Load, RPM
200 V, 200 V, 0.8 A., 430
200 V, 100 V, 1.2 A., 830
When I made my circuit (with AVR Microcontroller), it work 1 or 2 times only, then the relay –some time the bridge also- get damage. I used 15 Amp relay & 1000 V, 50 A Bridge.
I tried several solution, but it not solve the problem.
