Previous in Forum: Electronic Circuit Diagram for Phillips Monitor   Next in Forum: how to make a crane
arm Vs microcontroller
12/31/2008 12:44 AM
LPC2129 is given as an ARM7 processor in a material.. but the same has been mentioned as a microcontroller in the block diagram..
Actually what is the difference between the two.. and which has more advantages than the other
kindly reply to my ID
meet00796@gmail.com
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
Re: arm Vs microcontroller
12/31/2008 9:04 AM
Hello Guest,
It would be better to register with CR4 than to list your email address publically. Spiders crawl such information, and the result is unwanted email. CR4 has a private messaging system that you can use. Plus, you're more likely to get an answer as a registered member.
Hope you'll join us.
Moose
01/05/2009 8:19 AM
I come across your thread, I havnt used this chip, but I can tell you that arm7 is only a processor designed by an english company, when people adds some peripharies like ram, i/o ports etc. around it, it becomes microcontroller, like your 2129.
But I find my thread posted in this column was moved away and disappeared.
You might be interested in: Video Processor Boards, Cell Processors
