Previous in Forum: Vortex Meters and Flow Meters   Next in Forum: low pressure drain and high pressure vent line
valve recognition
01/03/2009 11:17 AM
can we recognize valves which are already in use in the field by just observing them from outside?
if yes, then i would be glad if you could provide me with a few tips
good day.
Re: valve recognition
01/03/2009 1:10 PM
Are you asking if you can determine whether a particular valve is a bonnet, diaphragm, butterfly etc?
Or are you asking whether or not a particular valve is in an open or closed postion.
Good Answers: 61
01/03/2009 3:21 PM
Chemengg, Yes you can if you do a little bit of home work first.
Go to "Google" and type in the name of various valve types.
"Gate Valve", "Globe Valve", :Butterfly Valve", "Check Valve", etc.
Pick a link that has pictures. Study the pictures and print them out. Take the print-outs to the field and use tham as an aide.
Each valve type has its own distinctive features and after a while you will be able to recognize most all of them.
With some of the valves you will also be able to tell if the valve is open or closed.
Do it once and do it right
01/04/2009 8:16 AM
Hi Chemengg,
You can recognize the valve type and sometimes the valve Fail action by using the pictures from 'Google'. It is not possible to say whether the valve is in good operating conditions without having a look on the valve internals(Trim parts). Also most valves looking similar outside have different internals depends on the process requirement. To recognize a valve in good condition or not we have to consider the Internal parts also.
Good Answers: 68
01/07/2009 10:35 PM
Hello PennPiper:
I have given you a GA. Your explanation was obvious, but, you made a subject which could have gotten complicated, simple! Thanks.
A small credit card sized example of open and closed valves. This is something I feel would be useful for all liquefied gas and petroleum, and other dangerous substance workers. Including of course Fire and safety teams.
Or has it already been done? If not they can call it after me!
Take care and have a great new year.....................
Hobbies - DIY Welding - pipewelder
01/04/2009 8:32 AM
Most valves have a spec tag on them all though some may not be very readable. I would first look for this tag to eliminate any guessing until you have more experience identifying valves from sight. I can usually identify whether a valve is a ball, gate, globe, butterfly, knife gate etc by just looking at them but I have been looking at them for 30 years. Every once in a while I will run across a full port ball OR a V-port knife gate that stumps me. The best way as already stated is to study the pictures and learn the characteristics. Another thing you can learn is how to identify the material of the valve from the casting markings on the the valve body such as WPB for carbon. You can usually find out how the different valve material is identified by going to some of the manufacturers' websites and reading how they mark them.
pipewelder
01/04/2009 9:00 AM
Absolutley. Identify the valve by their markings, crossreference to manufacturer. Never assume that because two valves are similar in appearance that they are the same. This is especially true as sizes and/or manufacturers vary. A large gate valve might appear very similar to a smaller butterfly etc.
Take the time to do things right.
01/06/2009 9:08 AM
Using the tag number, from the P&ID, look-up the maintenance records for a particular valve.
Register to Reply 7 comments
babybear (1); PennPiper (1); pipewelder (1); PWSlack (1); smkajith1985 (1); TexasCharley (2)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
