Previous in Forum: Motor winding dry out?   Next in Forum: Help with a DC circuit
HV-Surge Arrester
01/04/2009 8:29 AM
When mounting the surge counter the connection of the counter to the arrester bottom terminal should be isolated cable as per manufacturer instruction but what about the connection of counter opposite terminal that will be connected with the grounding grid, it also should be with insulated cable????????
Thanks
Re: HV-Surge Arrester
01/04/2009 10:47 AM
No It is not neccesary
Dartita
01/06/2009 2:52 AM
Dear Sir,
One terminal from the SA's base shall be connected with Inslauted with copper cable of suitable size. The other side can either be connected with GI, Copper falt or Alumium Cable alos. There is no definite rule how to ground.
Best Regards,
N.Suresh
01/27/2009 4:47 PM
Dear Guest,
There's no definite rule on that.
However, in my opinion, if it will be passing very near to equipments as it goes to the grounding grid, I would prefer an insulated wire/cable.
In our 138 kV 100 MVA power transformers, we have both sides of the counter insulated cables colored green.
Patriotism is the last refuge of scoundrels
01/27/2009 11:49 PM
Could you please send to me a photo of your system..?...
Thank a lot
02/02/2009 5:20 AM
The green cables are 4/0 stranded copper wires connected on both sides of the surge counters.
Anonymous Poster (2); iochoa (1); myn1996 (2)
