Previous in Forum: transformer cost   Next in Forum: Cause of Electrical Short Circuit Fires?
earthing
01/05/2009 10:15 AM
How can earthing be acheived in a ship?
Re: earthing
01/05/2009 8:34 PM
Welcome Kirchoff ,
You will do well to become familiar with the difference between 'earthing' and 'bonding', since the latter will serve your question better.
Earthing is known in many places as 'grounding'.
Here is a very informative link to read after you look up the difference between 'ground' and 'bond.
I do not 'know it all', but i will admit that I would like to. CJM
Re: earthing
01/05/2009 10:49 PM
IS EASY THE WATER IS YOUR GROUND SO IF THE HULL IS MADE OF STEEL YOU GET It, IF NOT YOU NEED TO MAKE IT BY EARTH PLATE AT THE BOTTOM OF THE HULL touching THE SEA WATER.
** All of my postings contain 100% recycled content. Nothing under the sun is new... including this**
Re: earthing
01/06/2009 9:40 AM
Quite.
Register to Reply 3 comments
CJMcGill (1); ELECTROENERGY (1); PWSlack (1)
You might be interested in: Industrial Cranes, Marine Services, Power Resistors
