I am interested in learning the reason why a phenomena occurs that I have observed. I have some thoughts about it, but am interested in others opinions.
I have obstructive sleep apnea and use a CPAP (continuous positive air pressure) medical unit to control the apneas during my sleep. The unit includes a length of corrugated flexible plastic tubing (tubing is ~1" ID with corrugations of ~3/16" and about 4 ft long) to couple the unit to a mask I must wear while sleeping. The tubing is to be flushed with water once or twice per week for cleanliness.
Anyhow, I typically will drape the tubing over the edge of the sink in a U shaped fashion and connect the one end to a faucet while holding the other end ~2-3" below the faucet outlet to direct the tubing discharge water into the sink basin. When I stop the flow of rinse water through the tubing it stops running into the basin; however, when I go to disconnect the tubing at the faucet, it spews water around the room and onto me.
I have also attempted to fill the tubing with water without direct connection to the faucet. I have observed that the water flows only with difficulty down the tubing which I hold open ended (both ends open and at the same level) in much the same U shaped manner as mentioned above. The water flow into the corrugated tubing is relatively slow for such a tubing size.
My question is why is this phenomena occurring? What is the source of this substantial backpressure. What am I missing here besides a raincoat?
