Previous in Forum: Free Wheeling Diode   Next in Forum: Generator Shortage
10 comments
Self-sustaining House Lighting
10/26/2006 11:12 AM
I am trying to build a house that is totally self sustaining.
I have the heating and hot water finished.
Dose anyone have any ideas on lighting? I only have 3k's to work with.
Pathfinder Tags: lighting self-sustaining
The Feature Creep
Re: Self-sustaining House Lighting
10/26/2006 2:05 PM
They built a Dilbert House a while ago that approached self sustaining. If your really interested they do into some in depth specs. I hope that helps. I think he might have had more energy generation capability that you. What's your power budget?
Lighting
  • Fluorescent lights for rooms that don't need to be dimmed
    • New technology is instant-on and no flicker
  • With proper ballasts, fluorescent lights are dimmable, but the cost of the ballasts erases the energy savings.
  • OTT(tm) light for desk areas, to avoid sadness from lack of sunlight
  • Motion detectors for lights in some rooms (bedrooms for example)
    • New light sensors use both infrared and motion detection
  • One switch panel for all lights in a room
  • Solar light pipes
  • No skylights (too much heat gain and maintenance)
  • Lots of lighting choices on interior. High priority.
  • Solar outdoor lights for landscape
"The future is here. It's just not widely distributed yet." -William Gibson
10/27/2006 12:40 AM
These are excellent recommendations. Recently-developed technology is taking dimming ballast cost down to a 'no additional cost' level. Hardware should be available in six months. Also, new versions of compact fluorescent lamps are available for bathroom 'light bars' and there are 3-way compact fluorescents for conventional table lamps.
Good Answers: 75
10/27/2006 1:22 AM
There are a lot of Light Emitting Diode solutions available now. The advantages are low power consumption, low voltage, use DC and if engineered correctly are extremely reliable. Use the Global Specs web site to search for LEDs, you will find heaps and if you play it right you may be able to get samples for nothing.
Good Answers: 247
10/27/2006 12:44 PM
I'm impressed. The heating and hot water are the hard parts. Lighting is relatively easy, and following suggestions of the other posters (I especially like the use of LED's) should give you a system that can be powered by just solar energy stored in batteries.
Safety - ESD - RF Manufacturing ESD Installer
10/27/2006 12:45 PM
I agree with the LED recommendation. I would also try to utilize interior light sources to thier full potential...possibly through fiber optic conductors (for localized needs) and reflectors to distribute light. Sky lights for daytime would be a must. (Thermal glass, naturally)
“The problems we face cannot be solved with the same level of thinking we had when they were created” Albert Einstein
Good Answers: 75
10/27/2006 2:33 PM
I can't remember where but sometime in the last week I read about a LED lighting module that had a red, green and blue LED that could each be controlled individually giving you not only intensity control but colour as well. I will try and find the reference and post it here.
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
10/27/2006 4:54 PM
Have you heard about the light tubes, that project in from the outside?
Skylights, solar lights usually used for the exterior. Do a search on architectural lighting etc.
All the best,
Ron Wagner
Good Answers: 75
10/28/2006 4:02 AM
I eventually found this. It's a 24 Watt 480 Lumens LED unit that you can adjust the intensity of the Red Green and Blue components so it give you the ability to not only change the intensity but the colour as well.
http://www.electronicproducts.com/ShowPage.asp?SECTION=3700&PRIMID=&FileName=hlap05.dec2006.html
Best of luck.
Good Answers: 75
10/30/2006 11:00 PM
I just received and E-Mail about a white LED that could pump out 140 Lumens and thought you might be interested. Follow the link for more details.
http://www.electronicproducts.com/ShowPage.asp?SECTION=3700&PRIMID=&FileName=hlap06.dec2006.html
04/08/2010 4:55 PM
I'm in the process of doing exactly what you have done, I"m curious to know what you did for your heating and hot water??
Register to Reply 10 comments
Anonymous Poster (1); Blink (1); BRodda (1); jowens (1); masu (4); ronwagn (1); scholar (1)
