Previous in Forum: Cause of Electrical Short Circuit Fires?   Next in Forum: Sensorless Vector and Closed Loop Control
In the U.K. until what power can an electrical motor start directly???
01/05/2009 8:16 PM
Hello!!!
I know that big electrical motors (with lots of power) need to start with an auxiliary system like star delta, an inverter, etc… Does anyone know if there is any 'law' in the United Kingdom that establishes a value of power from that has to be made? I searched the IEE wiring regulations, 17th edition but I couldn't find nothing…
Best regards and an happy 2009
Re: In the U.K. until what power can an electrical motor start directly???
01/05/2009 10:34 PM
Hi, in my opinion it will depend of the network that the motor is already connected, if you have enough available power to run the motor at seven times its nominal current per 2 or 3 second it will be fine, but you need to assure that there aren't other systems running at the same time otherwise you will have a blackout in the main breaker. Remember that kind of starting device are to induction motors and you can use this kind of auxiliary system when you want, normally over 5 kilowatts you will think in one auxiliary device, but again it will depend of your system, you need to make a calculus.
** All of my postings contain 100% recycled content. Nothing under the sun is new... including this**
01/06/2009 9:39 AM
Well, conductor size and supply capacity are two big factors. Get enough supply capacity and enough conductor cross-sectional area and anything is possible. Sadly, the economics of doing so get in the way.
