We installed MDF trim in a library. The joints had gaps and were not flush. We sent our technicians to repair and they used Bondo. Apparently they applied most of it after the "cure time" had been exceeded and there was no surface preparation other than wiping off the dust. Later after painting, the repair began to delaminate and the paint delaminated from the MDF. The discussion at this time is:
"Alex Volkoff called our office this morning regarding the interior trim repairs and suggestions as to what product to use. From his message below, it appears that he has come to the conclusion that a "drywall joint compound" (even with fiberglass joint tape) is not the product to use. Mike West and I have previously discussed these repairs on several occasions, and have come to the same conclusion.
Has any one asked the MDF board manufacturer for his recommendations? We suggest that you have Alex contact the MDF board manufacturer regarding recommendations as to material(s) and methods that are best suited to satisfactorily accomplish the repairs. Please let Mike and I know what you and Alex find."
We have reviewed the internet on what is used, Wood glue, wood filler, green skimming bondo, and more. No one seems definitive. Using an acrylic primer before whatever you apply seems required. This is an expensive repair. Doing it again will not be in our best interests. Does anyone have any ideas?
