Previous in Forum: mini dc generator   Next in Forum: Diversity Factor and Electrical Loads
neutral current
01/07/2009 2:51 AM
neutral current on bus bar is higher side
Good Answers: 137
Re: neutral current
01/07/2009 6:04 AM
Well there's a thing!
Re: neutral current
01/07/2009 10:57 AM
Current in the neutral can range from perfectly OK to indicating a serious problem.
Without better detail, we are powerless to help or even comment on your sentence fragment.
I do not 'know it all', but i will admit that I would like to. CJM
Re: neutral current
01/07/2009 8:32 PM
You need more information. What are the phase and neutral amperage.
Re: neutral current
01/08/2009 2:32 AM
Neutral current on higher side (above normal) is a serious issue. The cause can be found out with additional details. All phase currents, per phase THD. regards,
Ashish Gupta
Re: neutral current
01/10/2009 3:57 PM
The Neutral only carries the unbalanced current. Therefore you need to balance the load across the power phases. i.e phase A & B in a single phase application and phases A, B, & C in a three phase application.
Tell 'em what they need to hear; not what they want to hear!
ashuashi (1); CJMcGill (1); Codemaster (1); noshorts (1); wareagle (1)
