Is it possible to view a gap between two components, internal to a machine, by means of a fiber-optic or Lucite rod affixed to the outer surface of the machine, so that this gap or clearance can be observed through a "window" or view-port permanently attached to the external surface of the machine?
The gap would be .125" (3.1750mm).
The maximum distance between the gap and the exterior would be 12" (304.8mm).
