Previous in Forum: Another Way to Crimp Two Jumper Wires?   Next in Forum: DESIGNING FOR DBL HINGED EXPANSION JOINTS
17 comments
Tank Dishing Presses
01/08/2009 11:35 PM
I am looking to purchase a surplus or used press that will bump or press flat pie shaped blanks into double curved segments of dome and elliptical roofs for water tanks. The blanks are 8 feet in length and 5 feet in width on the wide end. Metal thickness is usually .25 to .50 A36 mild carbon steel plate.
The blanks can be formed a bump or a press at a time and be advanced into the press. In past have used old mechanical c frame presses with male and female dies.
I thought perhaps some of the members may work for companies that have surplus presses.
Thanks in advance for any help.
Pathfinder Tags: PRESSES
Re: TANK DISHING PRESSES
01/09/2009 7:24 AM
Do you need a press and the tooling also? I own a tool and die shop I could make a package deal for you, as you would need a good size press.
01/09/2009 6:48 PM
Tooling would be required at some point. At the moment we are using a male and female die with 8 foot radius made of hardened steel. The mail is on buttress threads and is turned counter or counter clockwise to achieve the desired bump radius.
With the right size press we will require various dies and will stack press.
What type, size, etc. presses do you have available ?
Re: Tank Dishing Presses
01/10/2009 1:18 AM
What are you looking for a 200 ton press or higher ?
01/10/2009 10:28 AM
We could make due with a 200 Ton. Due you have one or know of one ?
Thanks
01/10/2009 1:46 PM
I am checking with Valley Equipment to see if they have any left. The Chinesse were in last year and may have bought everything that was not nailed down.
Here is their web site not everything is listed on the web site might be worth a phone call.
01/10/2009 6:41 PM
Thanks for checking with bluevalley.
You mentioned another web site but didn't list it in your post.
Can you resend with web address.
Thanks
01/10/2009 7:53 PM
01/10/2009 1:46 PM
Would you prefer mechanical or hydraulic? I would think hydraulic would be better for forming a part.Mechanical would be better for punching.
01/10/2009 6:47 PM
Hydraulic or Mechanical would do the job. We currently use a 200 ton mechanical with a two foot diameter die the we turn clockwise or counter clockwise to change dish radius. It engages with a mechanical clutch and continues to cycle until disengaged. This allows sufficient time for the men to move the sheet side to side and advance into the machine as they come to the end of the side.
Hydraulic would be to slow for one piece at a time but would allow us to stack press several blanks at a time. Hydraulic would require dies for each of our standard tank heads. This would be a considerable investment but a huge savings in labor.
01/12/2009 9:50 AM
would you like a price on both methods?
01/12/2009 9:24 PM
I would like a price for both methods.
Thank you for your help.
01/13/2009 7:10 AM
Give me a call at Atlantic coast mfg...1-954-938-6228 and we can discuss it,
and I can get more details.
01/24/2009 12:04 PM
how about a 200 ton heim wioth a 10 ft bed?
01/25/2009 12:37 PM
Do you have any info. on the machine ?
Photo or two would help.
Thanks,
Tankguy
01/26/2009 7:16 AM
I will get all that I can and send it to you.
01/10/2009 11:23 AM
Have you looked into a Blue Valley
http://www.bluevalley.com/
phoenix911
02/14/2010 8:15 AM
Does anyone have a formula for spring back. We are pressing .25 inch thick A-36 plates into knuckle pieces for large diameter tank heads. The blank is 6' long and pie shaped with a 5' width in back and 3' width in front. The longitude's radius is 5.5' and the horizontal varies from 15' on large end to 22' on small end. We have made a die with ribs that have the compound radius. The dies are about 6 inches wider than the blank. The dies are also 1" larger than the blanks. We intend to start by over pressing by .25 inches and continue hoping to find our way the hard way. We are wondering if there is a formula to calculate the spring back.
Register to Reply 17 comments
dadw5boys (3); mtdmaker (6); phoenix911 (1); tankguy (7)
