In Fertiliser Industry, FSA, Sulphuric Acid and Rock is mixed in a vertical Mixer. The issue is that the Mixer boggs down frequently. The Mixer is a standard paddle in a tank type arrangement. The tank is lined with Poly Propylene. The reaction temperature is expected to be in the order of 100 deg C.
I considered PTFE, hoping that PTFE may have non stick properties and would assist in breaking the bond between liner and product, but there is no one in Australia that I know who can weld PTFE. Upon checking with one Contractor I learned that PTFE lining of cylinders with flanges is spun rather than welded, this led me to PFA which can be welded. But again I do not know anyone who can weld PFA.
My queries:
- Am I thinking correctly that PTFE or PFA will be better than PP with regards to coeff of friction?
- Is there any company that does welding of PFA?
- Is there anyone who has experience in similar industry who has solved this problem?
Look forward to hear from you. By the way, the reaction also generate Fluorine gas.
Prem
