Previous in Forum: dish washer   Next in Forum: Retiring value for a 12" pipe with nominal wall thickness 14.27mm
GE Make Frame-VI Gas turbine tripped on high vibration
01/10/2009 1:56 AM
GE Make Frame-VI Gas turbine tripped on high vibration DURING MACHINE normal shutdown, due to Bleed valve not open and high vibration create. Why this was happened ? Gas turbine Frame-VI, 30mw BHEL manufacured and Mark-V control.
Good Answers: 103
Re: GE Make Frame-VI Gas turbine tripped on high vibration
01/10/2009 2:23 AM
Why don't you contact GE or BHEL ? is it GE make or BHEL Make ?
01/11/2009 1:10 AM
Bleed valves are open during startup and shut down to prevent compressor stalls. The fact the turbine did trip on high vibration indicates that the bleed valve did not open and it was not a false indication. There may also be compressor damage due to compressor stall. The compressor should be borescoped prior to restarting.
As for possible causes.
1. The actuation cylinder on the bleed valve may be jammed.
2. Control air filter could be blocked. Check the small continuos moisture drain hole on the filter. If it gets blocked, water can accumulate in the filter and get into the contol air lines and cause problems
3. Control air solenoid valve could be stuck
01/11/2009 6:23 AM
whenever gas turbines trip on high vibration,the consequences are very serious.stalling/pulsation may have occured in your case,in my knowledge one of the gas turbines compressor got damaged due to this problem.If vibrations of all the bearings have crossed their maximum value and much more than that then there are chances of a possible failure of compressor/gas turbine.do not doubt your vibration sensors and go for a thorough inspection of your compressor and gt.kindly share what your findings were
01/11/2009 11:10 AM
Sounds like compressor stall, hope it didn't damage the compressor you'll have to investigate
02/03/2009 5:35 AM
You had a pressure pocket .
Anonymous Poster (1); dadw5boys (1); raggededgge (1); samundnarula (1); sb (1)
