Previous in Forum: design engineer   Next in Forum: rotor to journal bearing clearance
Reinforcement Pad
01/10/2009 6:46 AM
Reinforcement Pad
Generally where can i use Reinforcement Pad instead of tee or weldolet ?
Is there any limitation of pressure/temprature to use Reinforcement Pad....What are all the criteria for it's use....
Good Answers: 61
Re: Reinforcement Pad
01/10/2009 12:00 PM
You must get a copy of and read ASME B31.3
Re: Reinforced and Un-Reinforced Branches
Do it once and do it right
01/11/2009 2:05 AM
We prefer to use ready-made fittings for branching of piping systems. But in some cases we can use branch with reinforcing pad especially in piping systems under "not very high pressures nor temperatures", where we can use an integral flanges which are furnished with special nozzle thickness to compensate the need for reinforcing pad. Also, we can use a special piping fittings such as weldolets in making a branch to avoid using of reinforcing pad.
Note. If you apply the design conditions and pipe sizing, we can recommend the proper procedure required to make the proper pipe branch.
01/11/2009 3:19 AM
Also, please refer to the following CR4 Thread Reinforcement Pad for Long Weld Neck Flange.
Register to Reply 3 comments
