Previous in Forum: Impulse tubing procedure   Next in Forum: What is a HART Communicator?
temperature sensor
01/12/2009 12:53 AM
I found a temperature sensor/switch(I am not sure) which when dipped in liquid,a bulb glows dimly connected in series to it. Now,when the temperature of the liquid reaches a particular value,the bulb glows brightly. Can anyone tel me what this sensor is and how it works?
South Africa - Member -
Good Answers: 12
Re: temperature sensor
01/14/2009 1:36 AM
Hi there,
If you do not have an external voltage connected in the circuit - then it sounds as if you have a temperature sensor known as a thermocouple. You have two dissimilar materials and they generate voltage potential as the temperature changes. Seebeck discovered this principle.
For more information: http://en.wikipedia.org/wiki/Thermocouple
Regards,
Craig
Reply to Forum Thread
