Previous in Forum: Energy-Saving Lamps and the Stroboscopic Effect   Next in Forum: STARTER
Aluminum Wires vs. Copper Wires
01/12/2009 5:26 AM
I need to get convertion table to determine the size of winding alumunium wires in stead of copper wires.
Re: Aluminum Wires vs. Copper Wires
01/12/2009 11:43 AM
Good Answers: 128
01/13/2009 12:26 AM
Karmalamiri,
To get equal resistance, your aluminum wire must have 64% greater cross-section than the copper wire. This is the ratio of their resistances at 20°C. The table previously given was the USA's code table for building wiring, not insulated motor winding wires. As wire sizes get larger, the "skin effect" starts to become quite important in determining current flow and current-carrying capacity. However, in the sizes typical in most motors (but not always in form-wound large machines), the ratio of cross-sectional area is a good approach. You can see that aluminum conductors need more area in the slots of a motor than copper conductors. For that reason, a rewind of a stator using copper (when the old was aluminum) can be engineered to increase the motor's power output.
--JMM
Good Answers: 42
01/13/2009 3:14 AM
Your electrical code will have the sizing in it (US and Canada atl east).
Good Answers: 68
01/13/2009 8:31 AM
Hello karimalamiri:
And welcome as this seems to be your first thread?
I have to ask............why aluminium wires? If you are winding a motor everything is very much larger. Of course if you are rewinding a motor which had aluminium wires anyway, it makes sense. Just interested.
Are you in India and you wand a supplier from your local district?
I will put a couple of sites below. If you are not in India please tell me if you want these sites or do you have the things you need like wire, terminals etc ok?
123India.com Electrical : Companies : Business and Economy
Alcon Engineering Industries - copper and aluminium cable terminals .... Hi-Tech Resistors Pvt. Ltd. - manufacturer of wire wound, fusible & low ohm metal ...
dir.123india.com/business_and_economy/companies/electrical/ - 75k - Cached - Similar pages
High winding density micro coils for magnetic actuators 25 micron aluminum bonded wires complete the winding. on top. Figure 3 shows an externally wound micro coil with 400. turns of insulated copper wire ...
www.springerlink.com/index/A7Q9GVYUP74Y86XM.pdf - Similar pages
by J Klein - 1998 - Cited by 4 - Related articles
Take care and good luck...............
01/13/2009 10:42 AM
Sir:
Based on personal experience...I never use aluminum wires any more.
As a developer/contractor with several buildings of my own for 20 plus years.......aluminum wire has one very adverse problem.
Because of the co efficient of expansion......and aluminum's greater expansion by heat...if any where near utilized at greater than 70% of design load..the heat generated in the wire by supplying the load will cause a greater physical expansion of the wire...this compresses/deforms the wire, where ever held mechanically, by a set screw, kearney or terminal screw creating a situation after high load is no longer in the circuit...cooling back to ambient...leaving a less tight clamp at that connection...now possible slight arcing can occur...if so, greater additional heat is generated..arc again carbon created...offering added resistance next high loaded condition exacerbating the situation........with eventual fire or burn off wire.
In buildings I still own where aluminum wire has not been changed out........we at least annually inspect and re tighten those aluminum wire terminals.
I have just up graded/changed out to copper a building built in 1954....last one of mine left with aluminum on main service conductors.....
MR. GUY.
If you are looking for a positive answer..it's YUP......
08/23/2010 1:23 AM
Would ultrasonic soldering iron solve the use of aluminium wiring to copper terminate? We have successful solder dissimiliar metals using ultrasonic, which comes in portable handheld. Also successfully convert york coils cu wire to alu wire with minimum change to existing housing, through us of ultrasonic soldering pot.
Engineering Fields - Power Engineering - Siswanto
Good Answers: 15
01/18/2009 11:58 AM
Old technology Aluminum wire normally to be used for transformer winding, its designed to limited of short circuit current, currently Cu is using for almost of these winding, Some of Squirrel cage rotor bars still using of Al bars. you can modified from Al to Cu or v.v, but you must concerned to their material properties.
Modified from Cu to Al need much space to accommodate these conductors
following table may help you to calculation :
Properties
Aluminum
Copper
Electric Conductivity at 20 oC
62 %
100 %
Weight kg / Cubic Cm
0,546
1,803
Melting Point oC
6600
1083
Thermal Conductivity 20oC.
Cal / Sq Cm
0,57
0,941
Mechanical Strength
Annealed 1000 psi
13
32
Good luck
Rgds
Sis
LOVE FORUM AND DISCUSSION
Register to Reply 7 comments
Anonymous Poster (1); babybear (1); GW (1); jmueller (1); Mr. Guy (1); Siswanto (1); wareagle (1)
