Previous in Forum: Power transmission   Next in Forum: Please Help me to answer obout it
synchronization question
01/12/2009 10:05 PM
I have the two questions of synchronization. Can anybody answer or refer some useful links:
Question 1:
I used synchronizer to synchronize the generator to the infinite bus. I could do it because I have control for voltage and speed of the generator. Now, I need to use synchronizer to synchronize an infinite bus to another infinite bus. How it is possible when I don't have control over either of the buses.
Question 2:
What is the difference between the Sync Check and Synchronize.
Re: synchronization question
01/13/2009 3:26 AM
Your question is a bit confusing, you can synchronise a unit to the system because you have control over the unit speed and voltage, that is normal, to do so you have to select the synchronizer, that synchronizer is normally on the control panel for that unit only. System control then has control over the other circuit breakers on the infinite bus, as you call it, or the system at large. As a unit operator you will be advised by system, if necessary, to any adjustments to speed and voltage, if they need to close up the system.
Regards JD.
01/15/2009 2:32 AM
Sir,
You cant synchronise 2 buses when you dont have control. Generally during synchronisation the first one is taken as REFERENCE where the voltage, frequency are maintained constant. Of course the reference one has a specific phase sequence. Now you have to bring the second one to this stage for synchronising. When you both the buses are independant & you have no control over them then you cant make them parallel as they have different voltage, frequency levels.
Synchronising means two make parallel two sources. Check synchronisation means a relay which supervises these paramenters & closes the breaker for paralleling the supplies
01/15/2009 3:35 PM
Thanks very much for the response. It helps.
Anonymous Poster (1); jdretired (1); SABNAVEES (1)
