The vector group of transformers were discussed n this forum many times earlier.
Dy5 is, D - High voltage Delta connected and y- low voltage Star connected with 5 indicating code for 150 ° phase shift. The vector group is important for transformer parallel operation.
n = Star point in secondary is the neutral which is brought out to achieve phase voltage
5 = Indicates the CLOCK HOUR POSITION. Its 5 o clock which means the primary & secondary vectors are apart by 150 degrees mutually.
11= it indicates in the similar way as that of 5
The vector groups are mainly meant for paralleling. Transformers with similar vector groups only can be paralleled, otherwise there will be circulating currents in the total circuits.
In general the transformers with vector group Dyn11 are used for distribution purpose. Dyn5 are meant for specific purpose.
