I want only ac solenoid coils reistance calculation.Dc coils i know.
I want how calculate ac sov coil resistance.last day i go to attend a sov where name plate mention only watt and supply voltage.so i need to calculate resistance?
I measure the coil reistance that was 8.8 ohm. so i calculate i got 64 ohm that was wrong.so i take another 3 ac sov detail but i can calculate reistance dire
NOTE: ALL ARE AC COILS
EXAMPLE1:
VOLTS:24 AC
WATT:9.0
RESISTANCE:? I WANT TO CALCULATE(ACTUAL RESISTANCE 8.8 OHM MEASURE BY MULTIMETR)
EXAMPLE2:
VOLTS:230 AC
WATT:8.0
RESISTANCE:? I WANT TO CALCULATE(ACTUAL RESISTANCE 451 OHM MEASURE BY MULTIMETR)
EXAMPLE3:
VOLTS:110 AC
WATT:2.0
RESISTANCE:? I WANT TO CALCULATE(ACTUAL RESISTANCE 394 OHM MEASURE BY MULTIMETR)
MY question is this if i know 2 values(volts and watt) than what is the RESISTANCE vaule of coil?
1) resistance is also variable by temperature !! If temperature increases, resistance increases also.
2) impedance is also a function of the material your "coil-holder" is made of.an "air" coil and a coil "with electrical steel inside", can have exact the same number of wires and the same diameter of wire, but have a total different impedance.
You should also consider your amper turns as is required by the solenoid,this you can postulate from the dc operation then transfer the amps into your impedance calculation as a required wire size will affect the dc resistance and the overall impedance.
