Previous in Forum: Earthing Conductor   Next in Forum: Power Measurement (Electrical Engineering)
The difference in between body diode & freewheeling diode
10/28/2006 11:38 AM
In power electronics concepts I want to be sure on the difference in between body diode & freewheeling diode. Please, can any one help me on clearifying these concepts and thier differences?
Re: The difference in between body diode & freewheeling diode
10/29/2006 1:28 AM
Your description is somewhat vague but try this. If you are referring to a power FET there is an inherent diode from source to drain sometimes called a body diode. It happens to be in the right configuration to be used as a freewheeling diode in certain inductive switching applications. However, since it is a consequence of the construction of the FET and it is not generally intended to be use as a diode it is ill advised to do so. You should use a discrete device for that function and not rely on this secondary feature of the FET.
10/29/2006 8:16 PM
*** Quote from recapper ****
Re: The difference in between body diode & freewheeling diode 10/29/2006 10:28 AM
************** Quote Ends ***************
Body Diode is a new term to me I think it is somewhat
"Stray Diode" or Stray components. Anyhow it is OK for description
10/29/2006 8:19 PM
Please correct it to read" ***Quote from 'rcapper' Reply # 1 ***
10/30/2006 12:56 AM
I think I have heard it referred to as parasitic. It is the result of junctions formed between the active elements and the substrate. Since the substrate is the host to the transistor I suppose it gets the analog "body".
You might be interested in: Diode Arrays, Diode Lasers
