Previous in Forum: home plan   Next in Forum: Strengthening a Slab
Freezing Depth
01/14/2009 12:14 AM
I am designing underground pipe in very cold area.. min design temp = -35 C
could you please help me find what will be the minimum cover above the pipes? it would be greatly appreciated if I got this depth as a function of pipe material, soil type, and ny other factor contributing to this.... many thanks in advance
Re: Freezing Depth
01/14/2009 12:28 AM
Care to tell us where you live,type of climate,hemisphere of the earth?This stuff really helps.
CARPE CRUSTULORUM!
Good Answers: 74
Re: Freezing Depth
01/14/2009 1:48 PM
In central Alberta, temperatures of -35C occur from time to time. Depth of frost penetration varies depending on the amount of natural insulation, particularly the snow cover. In open areas, frost penetrates from six to eight feet. The soil type is predominantly clay.
Fine grained soils such as silts, fine sands and clays are frost susceptible. Coarse grained soils such as coarse sands and gravels are not susceptible to frost heave.
Bruce
Re: Freezing Depth
01/15/2009 1:34 PM
Another consideration for frost penetration is surface traffic. If your pipes are under roadways the depth of frost can be significantly deeper than surrounding untravelled ground, and that frost will be the last to come out during thaw.
In Calgary, water services are spec'd below 3m in order to be out of the freeze. On pipe penetrations for some of the plants I've work on, the pipes are insulated and heat traced 1.2-2m below grade.
If you are replacing native backfill, clean uniform gravel is key as any silty or clay lenses in the backfill will create frost lenses that become heaves that will impact your pipe.
What kind of piping are you designing?
Re: Freezing Depth
01/16/2009 10:46 AM
Thank you everybody! that was really healpful, and much appreciated!
I am using HDPE pipe, min 2m cover, and pipes are in trenches with pipe bedding, zonning and backfilling. there is specification for the materials to be used for trenching to meet common standards
Thanks alot!
Anonymous Poster (1); ba/ael (1); not so smart (1); rjyou (1)
