Previous in Forum: horse trailler registration   Next in Forum: reverse thruster for cars
trouble shooting automotive gauges,sensors,switches
01/17/2009 12:42 AM
Can anyone tell me how to troubleshoot speedometer,odometer,hourmeter,oil pressure gauge,air pressure gauge,ignition switch,exhaust brake switch,oil pressure sensor,speedo sensor,temperature sensor etc.What are the causes of their failure and how to correct them?
Good Answers: 62
Re: trouble shooting automotive gauges,sensors,switches
01/17/2009 8:24 AM
Too many different methods to get in one article.
Start with looking up a basic meter movement. Then understand that *most* of these take a value, convert it to a baseline for the meter and a differential for the movement for display. Look up the engineering sense of normalizing.
Then go to any given manufacturer's website and download the data sheet for given component you wish to know about.
For instance Jacobs makes both engine and exhaust brakes and explains every detail.
01/17/2009 6:45 PM
Yes sir it! And as you know by hook up a proper scaner through the onboard compu you may as well discover where the pain is, or also by compare a good one with the one you'll like to test. And sometimes the instrument may become just shot eventually and a new one is need. By keep checking it out it will come to you eventually. I know you can make it you have the knowledge go for it and make it happen. Allset! HehaaahiiHooHoo!!!!!!!!
You Have the Technology,
MC
01/18/2009 5:59 AM
ok i am sorry that i quoted a lot of names in a single thread.But it would be appreciated if you all will give the answer to any one of these components.
Good Answers: 62
01/18/2009 7:20 AM
Well, first start by registering because we like to work with people we know - it is free.
Second, put your question in context - do you have a vehicle with all of these broken, or did you need help organizing training material for yourself, or do you need to train your employees? We will help with any of the above, but better answers come from more information.
The short answer if you have one vehicle with all of these broken is you have an electrical problem. More modern vehicles use a sensor -> display system. The display may be run from the sensor or may be run from the vehicle computer.
So start by sorting:
Is all broken? Cab electric to the displays has failed. Or computer has failed, or computer electric has failed. All are fused, find the fuse and check it. First fuse to cab, then fuses to computer. Only after you are sure of power to cab and computer should you suspect computer.
Some are broken: Put your head under, is it a mixed display with some "wired" and some pipes under there? If older vehicle, some displays used no electric at all - such as pressure readouts, temperatures, speedometers: all could be run with the actual temperature or pressure they were reading. The "pipe" would be smaller than a pencil and run straight into the back of the gauge. There may be wires too, for lights at night.
If old "piped" mechanical readouts do not work, you have serious problems indeed. Pipes are crimped, or broken. These are hard and expensive to replace which is why all are electric now.
Get us more information for better answers. Glad to help.
You might be interested in: Pressure Gauges, Pressure Sensors, Pressure Switches
