Previous in Forum: Chiller's   Next in Forum: Formula for Journal Bearing Clearance
SEA
01/18/2009 2:23 AM
We have 1.5 MW genset ,Man made ,air started .The first start@25 bars .After many working days it took 30 bars to start ,so on building up air press. with time .We need u technical support
Engineering Fields - Transportation Engineering - VTOL nut
Re: SEA
01/18/2009 3:49 AM
sea, your question is unclear.
did you mean it takes more pressure to crank the engine, for it to start?
knowledge is like love; the more you share, the more you receive
Re: SEA
01/18/2009 4:41 AM
Yes it takes more pressure
Re: SEA
01/18/2009 4:55 AM
have you performance checks, compression pressure test(fuel cut-off), etc.
1. starting valve could be leaking/sticky.
2. inlet/exhaust valve leaking/burnt.
3. same thing to piston(s), i.e.:blowpass.
4. air distributor leakage.
Re: SEA
01/18/2009 3:31 PM
What kind of lubrication are you using in the Air Motor Satrter?
Bud Trinkel
Re: SEA
01/19/2009 2:19 AM
BudT, this is likely to be a direct air start type engine. air motor crank type engine don't normally operate at 20-30 bar...it's more likely to be 10bar max.
BudT (1); rmg21 (3); sea (1)
