Can any one advise how many kilowats are required for a coal crusher (sizer)
The coal will be running on a conveyor at 2.6 m/s, the sizer will need to run at aprox 20% faster than the conveyor. the conveyor is a trough of 700mm wide with the sizer set at 200mm high.
The motor speed will be 1450 rpm and we calculate the desired pick speed needs a 15:1.
How many kW do we need to size coal.
