Previous in Forum: Printing Press Motor / Drive Synchronization Problems   Next in Forum: steel
definition of root valve
01/20/2009 9:43 AM
i am working in a power plant.I agree with your answer about root valve but my colleages are of opinion that root valves are used in only instrumentation.please reply
Friend of CR4
Re: definition of root valve
01/20/2009 10:00 AM
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
01/22/2009 7:32 AM
Unless the definition has changed the first valve in any system is referred to as the root valve.
If you fail to follow through, you will fail.
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
