Previous in Forum: telescopic hydraulic   Next in Forum: USB Connections
Printing Press Motor / Drive Synchronization Problems
01/20/2009 7:28 AM
MAN Roland GEOMAN Newspaper Printing Press motor/drive. Is anyone familiar with this type of shaft less drive technology?
The issue we currently have is that not all drives will sync in together during initial start up.
Here is a brief description on how it works;
The web leads, page count, and color requirements are configured via software PPM (Press Planning Management). This information is then sent to the press PECOM system (Process Electronic Control Organization Management). Basically PECOM selects all required press equipment to be used to run the required format. PECOM also is the interface to enable the Press Operator in making the necessary electronic adjustments to produce a quality product, (color registration, ink and water balance, web tension, press speed, etc.).
Problem;
When the press is started all printing cylinders synchronize to achieve the proper circumferential registration. On occasion not all cylinders will sync in, we will either shut down the press and reload the planned job into PECOM or compensate the cylinders that did not sync in. This is causing a lot of paper waste and press down time. The drive system that is used on our press is manufactured by Baumuller and components consist of: Controller, Converter, Motor, and Encoder (Heidenhain ERN180). Any help or comments would be greatly appreciated.
Also posted in: also posted in Mechanical Engineering
Good Answers: 183
Re: MAN Roland GEOMAN Newspaper Printing Press motor/drive synchronization problems.
01/20/2009 8:01 AM
I do not know the system it self but I could pinpoint some aspects which are general.
You have two synchro problems : the speed and the angular position.
Usually the systems work with a master and slaves subsystems and the phases are corrected between slaves and master. If you get problems it means that the control loops have not same dynamics and have not same response when errors are detected.
It could be possible that installed powers/torques are not every where sufficient to accelerate components to the right speed in a short time and errors are due to the time constant of the control loop+mechanical connected components.
It could also be possible that the initial positions are too far from the correct one (settings) and lead to a long time required for compensation.
Those are as mentioned ONLY general thoughts.
Hope it will help.
Hobbies - Car Customizing - Dances with Trees Canada - Member - because I can Hobbies - CNC - too much fun Hobbies - Target Shooting - paper shreader
Re: Printing Press Motor / Drive Synchronization Problems
01/20/2009 9:38 AM
Being a former Pressman I love these kind of challenges. I would first ask if it is always the same cylinders that are not coming up to speed? My first guess would be the encoders or whatever you have reading cylinder rpm, for some reason I am thinking signal strength. Have you requested a new set of plates? Could be the registration is out on the digital plate processor to the point the system is having problems compensating. Intriguing, the more I think of possible issues the more variables seem to creep in, hard to make a good suggestion without seeing the operation. Personally i would start by eliminating all the external possibilities first, could be the press is fine.
Don't need a really good mechanic do you. I am looking for something new so I don't have to return to cubical land Not a great place for a creative mechanical person who really doesn't want to test software.
Sorry for the shamless plug, but if I don't do it...
Kevin "Dances with Trees" Willey
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
01/20/2009 10:03 AM
I'm afraid your problem can't be resolved distantly in no way unless by skilled service man from factory. I had been maintaining the printing press equipment some years ago. Needless to say I virtually lived there. A ton of reasons could cause a problem. What total counter shows? If there more than 5-10 mln, maybe the time has come to readjust your equipment. Is authorized service out of reach?
It's so unlikely the controller is the cause, none the less try turn off not only motors but all controllers/electronics for program resetting (more than 5 min). Sometimes it helps. Have you any means to readjust encoder(s) set up for you machine?
Check out all your sensors (especially photo). Wipe their optics surface out of paper's dust. If there are some assemblies like boss-cam-follower - check them how tight ones bolted and so on.
Has your machine test (slow motion or even handled) mode to observe when and how all sensors LED are switching.
It's not clear how was up the trouble - abruptly or gradually (during relatively long operating time)? Have been there another significant accidents?
All mechanical, electrical assemblies and parts should be checked and revised out with full attention.
Register to Reply 3 comments
caramba (1); Dances with Trees (1); nick name (1)
