Previous in Forum: Will a Record Player Stylus for 45's Properly Play 78's?   Next in Forum: Google It!
8 comments
Driveway Heaters
01/20/2009 11:10 AM
Is there any product available that can be installed under an existing driveway?
Re: driveway heaters
01/20/2009 11:21 AM
Mr. Google says:www.allwarm.com/driveway-heat.htm
And there are several others. You've just got to look.
CARPE CRUSTULORUM!
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Driveway Heaters
01/20/2009 12:05 PM
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
01/21/2009 9:05 AM
This stuff really does exist. Check out this Electric Radiant Heating link:
http://www.warmzone.com/gx-radiant-heating.asp
I expect the energy cost per hour would far exceed the hourly wage of a fleet of on call shovelers.
T
01/21/2009 9:46 AM
I used Britech ( www.britech.ca ) in my driveway it is way easier on the back than shovling at any cost.
Popular Science - Weaponology - Cardio-7
01/21/2009 11:02 AM
Of course. Start with (#1) small diameter steam pipes connected to a boiler, probably using Dowtherm or similar, (#2) look at the electric cables that are used to melt snow and ice from roof eaves and gutters, and last but not least, (#3) incorporate some radioactive waste, similar to the isotopes that are used for power generation for long-life satellites and interplanetary probes. Perhaps not a legal or viable solution, but a solution none the less.
01/22/2009 1:02 PM
Or get a GE F7A combustion turbine set up in your back yard (they are so unsightly in the front yard) and a HRSM for the heat rercovery. If you make it electric you will need that for power. The HRSM is Heat Recovery Snow Melter. This is where the economics of the GE installation really shows. Consider exhaust ductwork (for a nominal fee) to your neighbors driveways, patios, not too close to the house of course. Snow and ice will not stand a chance against the 1200+ degree exhaust. Better yet if you have some of those "problem neighbors" offer to clean and dry the roof with the exhaust or duct it directly into their house for "Free Heat"
Good Answers: 25
01/26/2009 11:20 AM
How do you keep the geese out?
Goodness has nothing to do with it.
Good Answers: 97
01/29/2009 11:50 PM
Dry very dry humor thanks
Register to Reply 8 comments
Anonymous Poster (2); beriberi (1); Bricktop (1); bwire (1); Cardio07 (1); Goodho (1); not so smart (1)
