Previous in Forum: future prospects for Telecommunication engineering   Next in Forum: Statically Indeterminate Structure by Superposition
Internal Combustion engine
01/20/2009 12:08 PM
why the thermal efficiecy of compression ignition engine increases with increase in compression ratio?
Arise, awake and stop not still the goal is reached.....
Re: Internal Combustion engine
01/28/2009 11:41 AM
This in in big part to the relativity of Pressures-Temperatures as more pressure the temperature increase as well. Like a pressure cooker effect. Now if you vacuum it it will require much less temperature to boil up and so on. Pressure-Temperature relation, very important. Good Question Buddies! You have the Technology!!!!!!!!!!
Keep it Cool,
MC
